[gdal-dev] Participating on gdal2tiles
Grégory Bataille gregory.bataille at gmail.com
Fri Jan 20 01:33:13 PST 2017
youhou... :)
ok, I'll see what I can do then
Gregory Bataille
On Fri, Jan 20, 2017 at 8:59 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On vendredi 20 janvier 2017 05:45:28 CET Grégory Bataille wrote:
> > Hi everyone,
> > I just subscribed to this list. Due to current interest, driven by my
> > current job, I'd like to participate on gdal2tiles.
> > However I'm not sure how to go about it and how active the development
> > still is.
> > I, for example, encountered an issue, that after investigation led me
> there
> > https://trac.osgeo.org/gdal/ticket/6057. It's a ticket with a proposed
> > solution and code patch, but that has seen no activity in 18 months.
> > Would you mind advising on the best way to contribute? Is the
> > development/review process, on gdal2tiles still active and is it worth
> > investing time on it?
> Hi Grégory,
> To be honest, I haven't processed gdal2tiles tickets for years as an
> experiment to see how much time it would take for an existing or new
> contributor to step up ;-)
> I'd suggest you to submit pull requests on the github mirror so that the
> Travis-CI tests are run on your patches. And I'd strongly encourage you to
> write new tests in ../autotest/pyscripts/test_gdal2tiles.py for each
> issue fixed.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170120/fdc24da4/attachment.html>
