[gdal-dev] Question about .aux.xml sidecar file handling...
Carl Godkin cgodkin at gmail.com
Fri Jan 20 11:43:34 PST 2017
On Thu, Jan 19, 2017 at 7:55 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> It seems that in ArcGIS 9.3, .aux.xml had their <GeodataXform> right at
> the root of the XML tree (so not at all compatible with GDAL .aux.xml
> formalism), and that in ArcGIS 10, they moved it as a GDAL PAM xml:ESRI
> metadata domain.
> I've just added in trunk support for reading those GCPs. The "fun" fact is
> that the (pixel,line) coordinates of GCPs are given not in pixels from the
> top-left corner of the image but in inches from the bottom-left corner...
Outstanding!  This is just what I need.
I was able to use today's version from GISInternals (great site, by the
way!!) to convert my files to a regular georeferenced GeoTIFF with
gdalwarp -tps USGS.tif output.tif
Thanks very much,
carl
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170120/33aa12ba/attachment-0001.html>
