[gdal-dev] Participating on gdal2tiles
Grégory Bataille gregory.bataille at gmail.com
Sun Jan 22 03:45:04 PST 2017
 ok thanks :)
Gregory Bataille
On Sun, Jan 22, 2017 at 11:47 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On dimanche 22 janvier 2017 11:21:06 CET Grégory Bataille wrote:
> > Yes it is. There was a commit on the test_gdal2tiles.py changing the
> > checksum values for test 1 :)
> Well, that's the life of a project that test results might change because
> of other changes. Not sure to understand if that's your issue, or if it is
> something Mac specific.
> > that's odd, it's pyflakes that is throwing me those warnings... well
> flake8
> > actually that is pyflakes + pep8. I'll have a look anyway.
> > And yes, the style commits need to be separate, no worries.
> > I did launch the vagrant by commenting this missing script. Now what is
> the
> > vagrant box supposed to do? my understanding is that is comes with gdal
> > installed (from trunk?)
> > I think the gdal2tiles.py test (and maybe some other python ones) are not
> > working in the vagrant box because those tests are looking for scripts to
> > test (gdal2tiles.py for example) in relative from the test file
> > test_gdal2tiles.py and because the Vagrantfile only maps the autotest
> > folder from the host to the client VM, the source for those python
> scripts
> > is not available in the VM.
> > Is it on purpose? would you see any issue mapping the source gdal folder
> > inside the vagrant box next to the autotest folder?
> Honestly I did the initial crack on setting up the Vagrant things as it
> was suggested it might help other people, but I don't use it personnaly, so
> it has probably rotten up, or might not be optimally done. The root folder
> (ie the one with the gdal/ and autotest/ directories) should probably be
> done. Feel free to do appropriate changes.
> > Sorry for the questions, it's always hard to enter into a project.
> > Last one actually for this mail:
> > I have an issue on a particular image. To test a fix (and non-regression
> in
> > the future) I can either try to do some mocking (but seeing how
> > gdal2tiles.py is not very modular, that might prove a nightmare) or use
> > some specific image that I know present the issue. If I want to test
> based
> > on an image, is it an ok practice to put the image in the repo (I can see
> > that there are several already but that doesn't seem like a great idea to
> > me). Any other common storage place (AWS S3 or whatever) that you would
> > have available or recommend otherwise?
> We must indeed be careful before adding new binaries (like images) in the
> repository to avoid its size to grow out of control. It is best if one can
> reuse existing images. Or create synthetic images that compress very well
> to few kilobytes or ten of kilobytes (sometimes the creation can be part of
> the test, so you don't have to store any binary in the repo). If the
> important thing is the size and georeferencing of the image, but not the
> pixel content, you can easily do a small black image with
> "gdal_translate in.tif out.tif -scale 0 1 0 0 -co TILED=YES -co
> SPARSE_OK=YES" (with trunk)
> Actually you can also do "gdal_translate in.tif out.vrt -of VRT" and edit
> the VRT to remove all <SimpleSource>. That will be even smaller.
> We don't have a project AWS S3 bucket, but we have
> http://download.osgeo.org/gdal/data/ where we can put some images. But it
> is a bit more cumbersome than having the images directly accessible from
> the SVN since you must do some checks (you can grep autotest/ for "
> http://download.osgeo.org/gdal/data/" to see how we use them)). And by
> default in the Travis-CI setups we don't enable those downloads from
> external resources because of the extra time it can take and reliability
> problems it causes.
> One aspect that might impact test is the proj.4 version being used. We
> don't currently have a requirement on the proj.4 version used and I'm
> pretty sure we have different versions used in the various Travis-CI +
> AppVeyor configs. So we sometimes have to add alternate expected checksums
> when the test result is sensitive to proj.4 changes.
> Writing tests might be non-trivial. I'm very well aware of the problem.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170122/d15939fd/attachment-0001.html>
