[gdal-dev] MBTiles from gdal2tiles vs. from gdal_translate
Even Rouault even.rouault at spatialys.com
Sun Jan 22 09:22:05 PST 2017
On dimanche 22 janvier 2017 16:17:19 CET Rahkonen Jukka (MML) wrote:
> Hi,
> In the "Participating on gdal2tiles" thread Mark Johnson wrote:
> "You might also consider incorporating the mbtiles implementation of a fork
> of gdal2tiles that can be found here:
> https://github.com/mj10777/gdal2mbtiles
> Here the goal was to also offer mbtiles as the output-format
> - instead of a tiles-directory"
> I would like to know what advantage/difference there is with saving
> gdal2tiles output into MBtiles format vs. using gdal_translate with MBTiles
> driver http://www.gdal.org/frmt_mbtiles.html
If an enhanced gdal2tiles had multiprocessing / multithreading support, that would be one
advantage.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170122/b8bf0146/attachment.html>
