[gdal-dev] MBTiles from gdal2tiles vs. from gdal_translate
Mark Johnson mj10777 at googlemail.com
Sun Jan 22 21:05:34 PST 2017
The main reason (at the time - over 4 years ago) was:
- that there was no write support for mbtiles then
  (as you no doubt saw in the link you provided)
I just tried gdal_translate on a sample file and see:
- that it (seems) to support only 1 zoom level
> Warning 6: driver MBTiles does not support creation option ZOOM_LEVEL
Whereas gdal2tiles supports a from/to zoom-levels
- creating the lowest level and then building the upper level from that
-- gdal_translate only does the first, but stops there
Since the main purpose of gdal2tiles is to create a set of tiles
- writing the output to a
-- tile-directory
or
-- a tile-database (which mbtiles is)
is a choice that should be offered.
In this case, the offered code is a full implementation of the mbtiles
specification
- where as gdal_translate seems to have only a minimal support
At the time, the Geopaparazzi Users used gda2tiles heavily
- but due to the restrictions of FAT32 on sdcard's was almost impossible to
use
After the implementation of writing mbtiles directly inside Geopaparazzi
was done
- the reported problems went down to a near 0
Since the need existed for many to use the Application where no Internet
connections exists, with the needed Zoom-Levels, this became a highly used
function.
There has also been no requests the extend the features offered, so the
implementation (which the python version was based upon) seem to fulfill
all the needs.
For gdal2tiles to create a result that is a single file
- is simply easier to employ and use
So the short answer would be:
- one is a full implementation - that would fulfill all needs
- the other a partial implementation - that does not fulfill all needs
Mark
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170123/376bba28/attachment.html>
