[gdal-dev] Call for discussion on RFC 67 : Null values in OGR
Jeremy Palmer JPalmer at linz.govt.nz
Wed Jan 25 12:11:18 PST 2017
Hi Even,
Change is most welcomed, especially for WFS/GML.
Would there also be changes required to the CSV driver given the new EMPTY_STRING_AS_NULL GDAL 2.1 open option?
Cheers,
Jeremy
On 26/01/2017, at 7:54 AM, Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>> wrote:
I've prepared a new RFC regarding the handling of null values in OGR.
https://trac.osgeo.org/gdal/wiki/rfc67_nullfieldvalues
No implementation proposed yet at this stage. I want to check if the proposed design choices make sense.
Even
http://www.spatialys.com<http://www.spatialys.com/>
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170126/af3984a7/attachment.html>
