[gdal-dev] even.rouault at spatialys.com
Even Rouault even.rouault at spatialys.com
Thu Jan 26 01:37:31 PST 2017
On jeudi 26 janvier 2017 09:08:01 CET Kemal Ardıl Gülez wrote:
> >> Hello all,
> >> I'm trying to read a WFS source. The GetFeature request to the WFS source
> >> returns rows in the form of:
> >> <gml:featureMember>
> >>     <groups fid="group.44107041">
> >>         <subgroupno>120</subgroupno>
> >>         <group>288</group>
> >>         <idno>40402578</idno>
> >>         <description>Descripton</description>
> >>         <groundref>56945117</groundref>
> >>         <hoodref>158699</hoodref>
> >>         <surfacearea>804.67</surfacearea>
> >>         <type>2</type>
> >>         <status>2</status>
> >>         <geom>
> >>             <gml:MultiPolygon srsName="
> >> http://www.opengis.net/gml/srs/epsg.xml#4326">
> >>                 <gml:polygonMember>
> >>                     <gml:Polygon>
> >>                         <gml:outerBoundaryIs>
> >>                             <gml:LinearRing>
> >>                                 <gml:coordinates decimal="." cs="," ts="
> >> ">67.58201,80.5654
> >>                                     67.58207,80.5652 67.58187,80.5653
> >>                                     67.58159,80.5654 67.58118,80.5654
> >>                                     67.58118,80.5655 67.58137,80.5655
> >>                                     67.58143,80.5655 67.58159,80.5654
> >>                                     67.58201,80.5654
> >>                                 </gml:coordinates>
> >>                             </gml:LinearRing>
> >>                         </gml:outerBoundaryIs>
> >>                     </gml:Polygon>
> >>                 </gml:polygonMember>
> >>             </gml:MultiPolygon>
> >>         </geom>
> >>         <createdate>2012-04-08T07:13:10</createdate>
> >>         <netsurfacearea>804.440800604637</netsurfacearea>
> >>         <typeid>2000000000001</typeid>
> >>         <supergroupstatus>2</supergroupstatus>
> >>         <parentstatus>3</parentstatus>
> >>     </groups>
> >> </gml:featureMember>
> >> But when I retrieve it with ogrinfo or ogr-fdw (which also uses OGR for
> >> reading and parsing any ogr data source) for postgres, the only fields
> that
> >> I can get are:
> >> - fid
> >> - geom
> >> - status
> >> - createdate
> >> Is this some kind of a problem with the WFS driver of OGR or is there
> >> something that I'm doing wrong or I have to do and I'm not doing?
> >Can you show the result of the DescribeFeatureType request, or better just
> provide the
> >endpoint to the WFS server and the layer used ?
> > Even
> The WFS server has IP restrictions so even if I provide it, you won't be
> able to consume it.
> Let me provide the DescribeFeatureType request to you.
> <xsd:complexType name="groupsType">
>     <xsd:complexContent>
>         <xsd:extension base="gml:AbstractFeatureType">
>             <xsd:sequence>
>                 <xsd:element maxOccurs="1" minOccurs="0" name="subgroupno"
> nillable="true" type="xsd:string"/>
>                 <xsd:element maxOccurs="1" minOccurs="0" name="group"
>                 <xsd:element maxOccurs="1" minOccurs="0" name="idno"
> nillable="true" type="xsd:long"/>
>                 <xsd:element maxOccurs="1" minOccurs="0" name="description"
>                 <xsd:element maxOccurs="1" minOccurs="0" name="groundref"
> nillable="true" type="xsd:int"/>
>                 <xsd:element maxOccurs="1" minOccurs="0" name="hoodref"
>                 <xsd:element maxOccurs="1" minOccurs="0" name="surfacearea"
> nillable="true" type="xsd:double"/>
>                 <xsd:element maxOccurs="1" minOccurs="0" name="type"
> nillable="true" type="xsd:short"/>
>                 <xsd:element maxOccurs="1" minOccurs="0" name="status"
>                 <xsd:element maxOccurs="1" minOccurs="0" name="geom"
> nillable="true" type="gml:GeometryPropertyType"/>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170126/0f4cd540/attachment-0001.html>
