[gdal-dev] WFS-T using OGR
Even Rouault even.rouault at spatialys.com
Fri Jan 27 03:21:43 PST 2017
On vendredi 27 janvier 2017 10:59:21 CET Ahmed Tolba wrote:
> Hi
> Thanks for your answer.
> I tried to do what you suggested, but I get " Can not insert the feature,
> because we didn't manage to parse the .XSD schema "
As the message suggests, the OGR WFS client didn't manage to get or correctly parse
the schema for the layer. This is a bit surprising as TinyOWS should generate simple
enough schemas for OGR to understand them. Difficult to know what happens
without being able to reproduce on my side.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170127/7263657a/attachment.html>
