[gdal-dev] shapefile field indexing on OGR 1.x vs 2.1
Andrea Battisti battisti at actgate.com
Tue Jan 31 04:42:34 PST 2017
>> Related to the attribute index: when using SQL WHERE clauses like
>> WHERE myfield IN (1, 2, 3) on the integer field, it reports on the last
>> one only, like if the query was
>> WHERE myfield = 3
>> (while there are rows with myfield = 1 and 2 as well...)
>> This is happening only if using the mapinfo attribute index on 2.1 (was
>> working on 1.x). If I manually remove the index files the query executes
>> correctly.
> Ah that's indeed a regression. I've just fixed it per
> https://trac.osgeo.org/gdal/ticket/6798
Thank you!
Andrea
