[gdal-dev] WFS-T using OGR
Ahmed Tolba Ahmed.Tolba at schiebel.net
Tue Jan 31 06:15:38 PST 2017
Can you please try with that server ?
WFS:http://192.168.139.128/cgi-bin/tinyows.exe?SERVICE=WFS&VERSION=1.1.0&outputFormat=JSON
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: Friday, January 27, 2017 12:22 PM
To: Ahmed Tolba
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] WFS-T using OGR
On vendredi 27 janvier 2017 10:59:21 CET Ahmed Tolba wrote:
> Hi
> Thanks for your answer.
> I tried to do what you suggested, but I get " Can not insert the feature,
> because we didn't manage to parse the .XSD schema "
As the message suggests, the OGR WFS client didn't manage to get or correctly parse the schema for the layer. This is a bit surprising as TinyOWS should generate simple enough schemas for OGR to understand them. Difficult to know what happens without being able to reproduce on my side.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170131/f940d219/attachment.html>
