[gdal-dev] gdal.Rasterize select output type different than Float64
Deschamps, Benjamin (AAFC/AAC) benjamin.deschamps at canada.ca
Tue Jan 31 06:19:28 PST 2017
Thank you, should have looked a bit further...
Benjamin
-----Original Message-----
From: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Rutger
Sent: January-31-17 6:01 AM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] gdal.Rasterize select output type different than Float64
Hey Benjamin,
This is fixed with 2.1.3, see (at the bottom):
https://trac.osgeo.org/gdal/wiki/Release/2.1.3-News
A workaround is shown at:
http://osgeo-org.1560.x6.nabble.com/gdal-RasterizeOptions-output-type-tp5293573p5293575.html
Regards,
Rutger
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-gdal-Rasterize-select-output-type-different-than-Float64-tp5305371p5305466.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
