[gdal-dev] GDAL Linux build / linking issue with ECW support
Candy, Liam Liam.Candy at angloamerican.com
Wed Jul 5 02:13:14 PDT 2017
I’m trying to build GDAL 2.2.1 with ECW (5.3) support. I’m having the linking issues that are documented on the wiki (https://trac.osgeo.org/gdal/wiki/ECW). I have tried the work around with the CXXFLAGS="-D_GLIBCXX_USE_CXX11_ABI=0" but without success, the issue persists (I’ve made sure the configure script is updating the CXXFLAGS in the make file - it is). Has anyone had a similar issue – and ideally a resolution ?
For reference, I’m on Ubuntu 17.04, gcc 6.3, GDAL 2.2.1, ERDAS ECW 5.3.0.
Best regards,
Liam.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170705/a0b1b126/attachment.html>
