[gdal-dev] GDAL Linux build / linking issue with ECW support
Even Rouault even.rouault at spatialys.com
Wed Jul 5 02:53:45 PDT 2017
On mercredi 5 juillet 2017 09:13:14 CEST Candy, Liam wrote:
> Hi,
> I’m trying to build GDAL 2.2.1 with ECW (5.3) support. I’m having the
> linking issues that are documented on the wiki
> (https://trac.osgeo.org/gdal/wiki/ECW). I have tried the work around with
> the CXXFLAGS="-D_GLIBCXX_USE_CXX11_ABI=0" but without success, the issue
> persists (I’ve made sure the configure script is updating the CXXFLAGS in
> the make file - it is). Has anyone had a similar issue – and ideally a
> resolution ?
> For reference, I’m on Ubuntu 17.04, gcc 6.3, GDAL 2.2.1, ERDAS ECW 5.3.0.
Did you make sure to "make clean" between each of your attempts ?
On Ubuntu 16.04 with GCC 5.4, the following works (I have to explictly disable a few C++ libs from the system, since they have been built the CXX11 ABI)
CXXFLAGS="-D_GLIBCXX_USE_CXX11_ABI=0" ./configure  --with-ecw=$HOME/hexagon/ERDAS-ECW_JPEG_2000_SDK-5.3.0 --without-libkml --without-armadillo  --without-cryptopp
I've also tried with GCC 7.1, so I guess that should also work with gcc 6.3
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170705/cc97adf1/attachment-0001.html>
