[gdal-dev] Use Kakadu "apps library" (#4116)
Even Rouault even.rouault at spatialys.com
Thu Jul 6 01:37:32 PDT 2017
Hi Philippe,
> A few days ago, I have updated a rather old ticket ( #4116
> <https://trac.osgeo.org/gdal/ticket/4116>  , 6 years old).
> I was just wondering if this update had been noticed, since I didn't want to
> open a new ticket.
Not sure I noticed it, but I see
https://trac.osgeo.org/gdal/ticket/6940 and the attached patch. It looks like #6940
is the cumulative patch for #4116 + building as a plugin, right ?
It seems your patch might break people using older Kakadu versions ?
Do you know what is the minimum one for which your patch can work ?
At least for documentation purposes (in which case, could you update the
nmake.opt line "# Uncomment and adjust paths if you have Kakadu 6.0 or newer
with the appropriate version)
Are people using Kakadu on Windows OK with that change ? If so, I'll (blindly, because of the
Windows + Kakadu combo) apply the patch of #6940 in trunk.
Ah, actually one thing to fix in
https://trac.osgeo.org/gdal/attachment/ticket/6940/gdal_kakadu_as_a_dynamic_plugin.patch
is to comment with # the KAK related lines. Otherwise this will break compilation for
default builds not using Kakadu. Would you mind updating it ?
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170706/5f303ca7/attachment.html>
