[gdal-dev] Build GDAL with PDFium
Gane R gane.prog at gmail.com
Mon Jul 10 09:11:16 PDT 2017
Hi all,
I tried to Build GDAL with PDFium on linux, I succeeded it.
 I faced the following issue
F .text._ZN13CFDF_Document12CreateNewDocEv       00000000000000ac .hidden
CFDF_Document::CreateNewDoc() *got that fixed by changing standalone.gypi
removing -fvisibility=hidden*.
As an next step *I tried to Build GDAL with PDFium for android(cross
compile)* I succeed it.
But when I try to* load the GDAL's shared library libgdal.so.20 which is
dependent for my shared lib libread.so. *
I see unsatisfied link error unable to load symbols in libgdal.so.20
U _ZN13CFDF_Document12CreateNewDocEv
U _ZN13CPDF_Document15AddStandardFontEPKcP17CPDF_FontEncoding
But I see
00000000 T _ZN13CPDF_Document15AddStandardFontEPKcP17CPDF_FontEncoding
00000000 T _ZN13CPDF_Document12CreateNewDocEv
in
pdfium/out/Release/obj.target/fpdfapi/core/src/fpdfapi/fpdf_edit/fpdf_edit_doc.o
(also in libfpdfapi.a)
any suggestions on this issue or any one has worked on this will of great
help.
Gane R
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170710/d9fec727/attachment.html>
