[gdal-dev] Python feature.SetField() fails with unicode strings
Roger André randre at gmail.com
Mon Jul 24 11:36:30 PDT 2017
Hi Even,
Thank you for this information.  I'll see about getting the latest version
of GDAL installed on my system.  I tried using the string.encode('utf-8')
workaround and continue to get the same error.
Roger
On Mon, Jul 24, 2017 at 8:46 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On lundi 24 juillet 2017 08:43:02 CEST Roger André wrote:
> > Good morning,
> > I've been working on a simple script to load GeoJSON into PostGIS. I'm
> > encountering an error that has me scratching my head, it seems that
> unicode
> > strings cannot be used with the feature.SetField() function in Python. Is
> > that really true?
> > I've tested this by re-writing the variable inline from my test record
> and
> > can confirm that when it is type <str> it works, and when it is type
> > <unicode> it fails with the following error.
> > *NotImplementedError: Wrong number of arguments for overloaded function
> > 'Feature_SetField'.*
> > I foind an old ticket that talks about this,
> > https://trac.osgeo.org/gdal/ticket/4608, but I'm not having any luck
> > getting this to work.
> This ticket was fixed in GDAL 2.0. There might have been other fixes
> since. So basically you should try upgrading. Or as a workaround use
> your_string.encode('utf-8') to transform from Unicode to UTF-8 encoded
> string.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170724/1d693d3f/attachment-0001.html>
