[gdal-dev] DataSource/Dataset using gdal.Grid()
Kai Mühlbauer kai.muehlbauer at uni-bonn.de
Thu Jun 1 12:48:23 PDT 2017
Am 1. Juni 2017 21:27:06 MESZ schrieb Even Rouault <even.rouault at spatialys.com>:
>> Thanks Even, for the fast response. You mention the OGRDataSource as
>legacy.
>> I wasn't aware of that fact. Is there anything important to know
>about
>> that, because I would need to port quite some code to use the
>GDALDataset.
>Have a look at https://svn.osgeo.org/gdal/trunk/gdal/
>MIGRATION_GUIDE.TXT
>and particularly
>http://trac.osgeo.org/gdal/wiki/rfc46_gdal_ogr_unification
Thank you again for the pointers. Seems, that my needed changes are not that hard to code.
Cheers,
Kai
