[gdal-dev] libcurl and the certificates and Windows
Joaquim Luis jluis at ualg.pt
Sat Jun 3 10:29:34 PDT 2017
For reference
https://github.com/curl/curl/issues/1538
> On Sat, 03 Jun 2017 17:22:33 +0100, Even Rouault
> <even.rouault at spatialys.com> wrote:
>> On samedi 3 juin 2017 17:04:07 CEST Joaquim Luis wrote:
>>> Hi,
>>> For quite some time I cannot use the 'vsis' because of certificates
>>> issue.
>>> For example, a GMT test that has a command like this no longer works on
>>> Windows
>>> gdalinfo
>>> /vsicurl/http://larryfire.files.wordpress.com/2009/07/untooned_jessicarabbit
>>> .jpg
>>> because
>>> ERROR 11: HTTP response code: 301 - SSL certificate problem: unable to
>>> get
>>> local issuer certificate
>>> gdalinfo failed - unable to open
>>> '/vsicurl/http://larryfire.files.wordpress.com/2009/07/untooned_jessicarabbi
>>> t.jpg'.
>>> It used to work but probably with an older libcurl dll.
>>> The above is with my own build gdal and dependencies (libcurl included)
>>> but the same happens with the gisinternals binaries.
>>> I have re(and re)ad this page about the certificates
>>> https://curl.haxx.se/docs/sslcerts.html
>>> but regarding Windows and the curl-ca-bundle.crt file what is said
>>> about
>>> it simply does not work. The only thing that works is setting the ENV
>>> variable
>>> set CURL_CA_BUNDLE=V:\bin\curl-ca-bundle.crt
>>> Now, we had this in GMT recently and I used the nuke option
>>> curl_easy_setopt (Curl, CURLOPT_SSL_VERIFYPEER, 0L); /* Tell libcurl to
>>> not verify the peer */
>>> so tried to do the same thing in the GDAL code (the obvious point
>>> seamed
>>> to be VSICurlSetOptions in cpl_vsi_curl.cpp) but still does not work.
>> Someone reported to me a similar issue with recent OSGeo4W.
>> Did you try setting GDAL_HTTP_UNSAFESSL=YES? This is taken into account
>> in CPLHTTPSetOptions() that is called by VSICurlSetOptions(), >>and
>> this set CURLOPT_SSL_VERIFYPEER=0 and CURLOPT_SSL_VERIFYHOST=0.
>> This solved the issue.
> Thanks, yes that works too (and, no I hadn't tried it before) although
> it's a different solution than setting  CURL_CA_BUNDLE , which does not
> turn >out the certificates verification.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170603/825d5801/attachment.html>
