[gdal-dev] gdalenhance command issue with stddev option
Even Rouault even.rouault at spatialys.com
Tue Jun 6 01:14:59 PDT 2017
On lundi 5 juin 2017 23:52:22 CEST naresh wrote:
> Dear Rahkonen,
> Thanks for the quick response. However with gdalenhace  -help  showing the
> -stddev option. Please find the attache screenshot.
>    [image: Inline image 1]
>  Is there any other mechanism/tool is available for enhancing the images
> with stddev option.
You can run gdalinfo -stats in.tif
note the mean and stddev values
and then compute
s_min=mean - factor * stddev
s_max= mean + factor * stddev
gdal_translate in.tif out.tif -scale s_min s_max 0 255
Best regards,
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170606/051fd1fe/attachment.html>
