[gdal-dev] Unable to obtain EPSG from OGRSpatialReference
Mike K jujumbura at hotmail.com
Wed Jun 7 10:51:44 PDT 2017
Nik Sands, thank you, you nailed it.
That was my problem: the UTM coordinate system I was expecting is projected,
so I needed to use those functions you listed with the "PROJCS" key to get
the proper EPSG code.  Once I parsed out the code, I get 32617 as expected.
Thank you all!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Unable-to-obtain-EPSG-from-OGRSpatialReference-tp5323281p5323403.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
