[gdal-dev] .exe extension missing for gdal-2.2.0 binaries
Velagandula, Sravan Kumar sravan.velagandula at openscg.com
Fri Jun 9 03:01:12 PDT 2017
Hello Even,
    I see that the value of ${host_os} is "mingw64" for gdal-2.20 and
"mingw32" for gdal-2.0
gdal-2.2
Host OS: 'mingw64'
gdal-2.0.3
Host OS: 'mingw32'
Thanks,
Sravan
On Fri, Jun 9, 2017 at 2:00 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On vendredi 9 juin 2017 12:16:17 CEST Velagandula, Sravan Kumar wrote:
> > Hello,
> > I am trying to build gdal-2.2.0 from source on windows 7 64 bit using
> > msys2 environment. gcc is 4.8.3.
> > This is the source I am using:
> > http://download.osgeo.org/gdal/2.2.0/gdal-2.2.0.tar.gz
> > The binaries produced do not have the .exe extension. But building the
> > gdal-2.0.3 produces the binaries
> > with the .exe extension. I am wondering if anyone else has across this
> > issue and if so if they were able
> > to find a resolution. I appreciate your help.
> Sravan,
> I don't think this aspect of the project has changed in years. Did you use
> the same msys/mingw toolchain when compiling GDAL 2.0 and GDAL 2.2 ? I
> suspect not
> In configure.ac, the relevant snippet is :
> dnl ------------------------------------------------------------
> dnl Check whether we need to add specific suffix for executables (.EXE when
> dnl building for Windows). This test should work for the case of
> dnl cross-compilation too.
> case "${host_os}" in
> cygwin* | mingw32* | pw32*)
> EXE_EXT=.exe
> SO_EXT=dll
> EXE_EXT=
> esac
> I suspect that your toolchain is identified a bit differently.
> Could you open "configure" in a text editor and add the following lines at
> the end of it :
> echo "-------------------------"
> echo "Host OS: '${host_os}'"
> Then run configure again and report the value displayed
> For example with the x86_64-w64-mingw32 cross-compilation toolchain (host:
> Linux), I get the following, which matches the above expressions
> Host OS: 'mingw32'
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170609/1cdd30de/attachment-0001.html>
