[gdal-dev] .exe extension missing for gdal-2.2.0 binaries
Velagandula, Sravan Kumar sravan.velagandula at openscg.com
Fri Jun 9 03:14:07 PDT 2017
I apologize for not having confirmed that I am using the same toolchain for
both the builds.
Thanks for the valuable feedback. I would tweak the configure script to get
my builds going.
- Sravan
On Fri, Jun 9, 2017 at 3:40 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On vendredi 9 juin 2017 15:31:12 CEST Velagandula, Sravan Kumar wrote:
> > Hello Even,
> > I see that the value of ${host_os} is "mingw64" for gdal-2.20 and
> > "mingw32" for gdal-2.0
> OK, so with a different toolchain between both builds ?
> Anyway, should be now fixed per https://trac.osgeo.org/gdal/ticket/6919
> that changes the mingw32* pattern to mingw* to catch both cases.
> Or you can just edit GDALmake.opt after ./configure , look for the
> EXE =
> line and modify it as
> EXE = .exe
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170609/8e557155/attachment.html>
