[gdal-dev] Building with plugins...
Carl Godkin cgodkin at gmail.com
Mon Jun 12 10:55:11 PDT 2017
Thanks very much.  (No wonder I couldn't find much information about these
things anywhere!)
carl
On Mon, Jun 12, 2017 at 10:44 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On lundi 12 juin 2017 08:04:08 CEST Carl Godkin wrote:
> > Hi,
> > I am interested in building GDAL 2.2.0 with some of the available drivers
> > as plugins.
> > 1. Is the procedure for building GDAL plugins documented anywhere for
> > Linux?
> I don't think so. Plugin building in Linux is more experimental/advanced.
> > I see that there are several variables like XXX_PLUGIN listed in
> > nmake.opt for Windows but I'd like to use plugins on Linux as well and
> > can't see any relevant arguments for "configure" (except
> > --enable-pdf-plugin).
> There's also the GRASS plugin that has its own configure. And
> Debian/Ubuntu has a package with a configure to build the ECW (and MrSID I
> think) plugins. Otherwise except for the PDF plugin, you need to tweak
> yourself the makefile if you need a driver build as a plugin.
> > 2. Is there a list of which drivers can be built as plugins anywhere? (I
> > know that the GISInternals build provides about 10 drivers as plugins but
> > the many commented-out drivers in nmake.opt leads me to believe that
> there
> > could be even more than that.
> Well, basically the list in nmake.opt should be pretty much what is
> available:
> $ grep _PLUGIN nmake.opt | grep "#"
> #ECW_PLUGIN = YES
> #JP2LURA_PLUGIN = YES
> #TD_PLUGIN = YES
> #HDF4_PLUGIN = NO
> #HDF5_PLUGIN = NO
> #KEA_PLUGIN = NO
> # INGRES_PLUGIN = YES
> #FITS_PLUGIN = NO
> #NETCDF_PLUGIN = NO
> #OCI_PLUGIN = YES
> #SDE_PLUGIN = NO
> #FGDB_PLUGIN = YES
> #AMIGOCLOUD_PLUGIN = YES
> #ARCOBJECTS_PLUGIN = YES
> #SOSI_PLUGIN = YES
> #PDF_PLUGIN = NO
> #MONGODB_PLUGIN = NO
> # MONGODB_PLUGIN = YES
> > Thanks very much,
> > carl
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170612/51ffcff9/attachment-0001.html>
