[gdal-dev] Problem in ogr converting polygon coverages
Even Rouault even.rouault at spatialys.com
Thu Jun 29 12:28:19 PDT 2017
Brent,
> I'm having trouble with OGR converting ESRI polygon coverages to
> shapefiles.  Basically the newer versions of ogr ignore the attributes
> on the polygons and show only the ArcIds attribute. Looks like a bug
> possibly introduced during RFC 50
> (https://trac.osgeo.org/gdal/wiki/rfc50_ogr_field_subtype).
I don't think this is related. More likely a regression caused by a code cleanup/hardening.
>    If there is a option to the command line to fix this, please let me
> know, otherwise I'll file a bug report.
Please file a bug report
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170629/913e4d0e/attachment.html>
