[gdal-dev] Problem in ogr converting polygon coverages
Brent Fraser bfraser at GeoAnalytic.com
Thu Jun 29 15:55:39 PDT 2017
You're awesome Even!  Thanks!
 Brent
 From: "Even Rouault" <even.rouault at spatialys.com>
Sent: Thursday, June 29, 2017 2:29 PM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Problem in ogr converting polygon coverages
On jeudi 29 juin 2017 21:28:19 CEST Even Rouault wrote:
> Brent,
> > I'm having trouble with OGR converting ESRI polygon coverages to
> > shapefiles. Basically the newer versions of ogr ignore the attributes
> > on the polygons and show only the ArcIds attribute. Looks like a bug
> > possibly introduced during RFC 50
> > (https://trac.osgeo.org/gdal/wiki/rfc50_ogr_field_subtype).
> I don't think this is related. More likely a regression caused by a code
> cleanup/hardening.
> > If there is a option to the command line to fix this, please let me
> > know, otherwise I'll file a bug report.
> Please file a bug report
Actually I've just done it with https://trac.osgeo.org/gdal/ticket/6950 and
committed the fix.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170629/6484f92d/attachment.html>
