[gdal-dev] Linking against gdal201.dll with different MSVC versions
Jürgen E. Fischer jef at norbit.de
Thu Mar 2 02:14:07 PST 2017
Hi Even,
On Thu, 02. Mar 2017 at 10:43:16 +0100, Even Rouault wrote:
> Probably because the last GDAL built in OSGeo4W was done with MSVC2010,
> before the recent upgrade to MSVC2015 for QGIS master. I guess the next GDAL
> builds will be done with MSVC2015 too.
Well, if the third party dependencies (like filegdb - which I happend to start
and stop checking) were available that would already be in place.
Maybe I should just drop it in favor of openfilegdb - that's going to happen if
it's still not available when gdal switches to C++11.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170302/f2c421f7/attachment-0001.sig>
