[gdal-dev] Testing of OGR generated GeoPackage datasets with other implementations
Even Rouault even.rouault at spatialys.com
Thu Mar 2 05:04:39 PST 2017
I've committed recently a small improvement regarding vector and attribute tables in the
GeoPackage driver, so as to get the number of features quickly. This can be interesting when
dealing with huge tables. Without that, getting the number of features require a full table
scan. So I've added a "ogr_feature_count" column to the gpkg_contents table, and triggers to
update it.
To my understanding, such an extension is allowed by the specification.
While running through the OGR GPKG driver those triggers are temporarily disabled during
feature insertion and deletion so as to make them faster, and restored back at dataset
closing.
The driver of course behaves well if the column is missing or if its content is NULL (will revert
to full table scan to get feature count)
Earlier versions of the OGR GPKG driver are also happy with the new layout of the DB.
As a provision, I've added a ADD_OGR_FEATURE_COUNT_COLUMN=NO dataset creation
option to disable this, but it is my hope this will be not needed.
So I'd be interested if people could test
http://even.rouault.free.fr/geopackage/ne_10m_admin_0_countries_france.gpkg
(or any other gpkg you may generate with today's ogr2ogr) with other software package that
don't use OGR underneath (ArcGIS for example).
Suggested tests:
- check that the DB opens well and the layer is listed
- check that the layer opens well (you should see France and its overseas territories)
- check that you can add or delete features to the layer. Check afterwards that the
ogr_feature_count is well updated (it should, thanks to the triggers):
ogrinfo ne_10m_admin_0_countries_france.gpkg \
   -sql "select * from gpkg_contents"
- check that you can add a new layer to the DB (ie insertion of new content in gpkg_contents
works well, despite the new column added). The value of the ogr_feature_count column
should be NULL.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170302/9c279c48/attachment.html>
