[gdal-dev] Testing of OGR generated GeoPackage datasets with other implementations
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Thu Mar 2 05:55:19 PST 2017
Hi
Right, ne_10m_admin_0_countries_france_no_ogr_feature_count.gpkg opens with MapInfo 15.2.
-Jukka-
Lähettäjä: Even Rouault [mailto:even.rouault at spatialys.com]
Lähetetty: 2. maaliskuuta 2017 15:49
Vastaanottaja: gdal-dev at lists.osgeo.org
Kopio: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
Aihe: Re: [gdal-dev] Testing of OGR generated GeoPackage datasets with other implementations
On jeudi 2 mars 2017 06:36:06 CET jratike80 wrote:
> Even Rouault-2 wrote
> > So I'd be interested if people could test
> > http://even.rouault.free.fr/geopackage/ne_10m_admin_0_countries_france.gpk
> > g
> > (or any other gpkg you may generate with today's ogr2ogr) with other
> > software package that
> > don't use OGR underneath (ArcGIS for example).
> Hi,
> MapInfo Pro 15.2 does not open your geopackage. It does open the geopackage
> which I cleaned with a bit older GDAL build as
> ogr2ogr -f gpkg clean.gpkg ne_10m_admin_0_countries_france.gpkg
> MapInfo did not give any error message, it just does not find any layers and
> quits. I could not find anything like error log from MapInfo directory. I
> will send a message to MapInfo support as well with a link to your
> geopackage.
Thanks for your feedback
Interesting, would you mind testing
http://even.rouault.free.fr/geopackage/ne_10m_admin_0_countries_france_no_ogr_feature_count.gpkg
which is the same with today's trunk but with -dsco ADD_OGR_FEATURE_COUNT_COLUMN=NO
If that works (and it should probably given your above testing), that means I should revise my design as
we want to be compatible with existing implementations.
I've though of an alternative that would use an auxiliary table instead of extending gpkg_contents, like a
gpkg_ogr_contents table. I've simulated it manually in
http://even.rouault.free.fr/geopackage/ne_10m_admin_0_countries_france_alternative.gpkg
Generated with :
cp ne_10m_admin_0_countries_france_no_ogr_feature_count.gpkg ne_10m_admin_0_countries_france_alternative.gpkg
ogrinfo ne_10m_admin_0_countries_france_alternative.gpkg -sql "CREATE TABLE gpkg_ogr_contents (table_name TEXT NOT NULL, feature_count INTEGER DEFAULT NULL)"
ogrinfo ne_10m_admin_0_countries_france_alternative.gpkg -sql "INSERT INTO gpkg_ogr_contents VALUES ('ne_10m_admin_0_countries', 1)"
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170302/70d3c23f/attachment.html>
