[gdal-dev] Geopackage ogr2ogr append question
Neumann, Andreas a.neumann at carto.net
Fri Mar 3 07:14:54 PST 2017
Hi Even,
Thanks for your reply.
My gdal version is 2.0.2 - I can update to a newer version and see if
this warning disappears.
I meanwhile also figured out that I need to use -nln for proper table
names.
Thanks also for the information about append vs. update. I'll switch to
update then.
Andreas
On 2017-03-03 15:53, Even Rouault wrote:
> Hi Andreas,
>> I am, for the first time trying to append additional tables with ogr2ogr
>> to an existing Geopackage file and have questions:
>> ogr2ogr -progress -lco SPATIAL_INDEX=YES -f GPKG av_1700_lv03.gpkg
>> PG:'dbname=publikation host=localhost schemas=av_1700' -sql "SELECT
>> t_id, t_ili_tid, geom_03, bfs_nr, gemeinde, bodenbedeckungsart,
>> bodenbedeckungs_flaeche, gebaeudenummer, gwr_egid, objekt_name FROM
>> av_1700.bb_bodenbedeckung"
>> ogr2ogr -progress -append -f GPKG av_1700_lv03.gpkg
>> t_id, t_ili_tid, geom_03, bfs_nr, gemeinde, linienart, bobeart_links,
>> bobeart_rechts FROM av_1700.bb_bodenbedeckung_kanten"
>> First question:
>> is the -append option enough or do I also need the -update option?
> Yes -append is enough. It implies -update.
> But -append is for appending features to an existing table. If you need to create a new table, you just need -update.
> In your above case, you must be careful. The name of a SQL result layer depends on the driver. I nthe GPKG driver, it is always "sql_statement". You might want to rename it to something more useful with -nln new_layer_name,
>> Second question:
>> I get warnings:
>> Warning 1: Layer sql_statement relies on the 'gpkg_geom_COMPOUNDCURVE'
>> (GeoPackage 1.0 Specification Annex J) extension that should be
>> implemented for safe write-support, but is not currently. Update of that
>> layer are strongly discouraged to avoid corruption.
>> Warning 1: Layer sql_statement relies on the 'gpkg_geom_CURVEPOLYGON'
>> Can I safely ignore these messages? Or is there a creation option for
>> the first table that enables this extension?
> Which GDAL version is this ? It looks like the issue of
> https://trac.osgeo.org/gdal/ticket/6402
> So this should be fixed in GDAL 2.0.3 or GDAL >= 2.1.0
> (the warning can be ignored, but you should upgrade to a more recent version so that the extension is properly registered as read-write)
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170303/795d54b6/attachment-0001.html>
