[gdal-dev] Proposed ogrmerge.py utility script
Even Rouault even.rouault at spatialys.com
Mon Mar 6 01:21:32 PST 2017
On samedi 4 mars 2017 04:42:54 CET jratike80 wrote:
> Even Rouault-2 wrote
> > Opinions on script naming (I also tought to ogrcat.py to reflect the
> > similarity with the Unix cat
> > utility used to concatenate files), option naming, etc.. are welcome
> Hi,
> ogrmerge.py is good name for the script.
> I would rename  -overwrite_lyr into -overwrite_layer. It pays only two
> letters, "layer" is already used in other parameters, and users would
> understand with less thinking what it means.
Committed into trunk with your remark taken into account.
https://svn.osgeo.org/gdal/trunk/gdal/swig/python/scripts/ogrmerge.py
Note: it can be used with GDAL 2.1 as well.
Online help page at :
http://gdal.org/ogrmerge.html
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170306/bad291bf/attachment.html>
