[gdal-dev] Getting black lines between doqqs
Stephen Woodbridge woodbri at swoodbridge.com
Mon Mar 6 12:52:03 PST 2017
Thank you Even! that was the trick and it works great now.
On 3/6/2017 1:35 PM, Even Rouault wrote:
> On lundi 6 mars 2017 13:20:50 CET Stephen Woodbridge wrote:
>> Hi,
>> I have a collection of doqqs that look like the two below. I trying to
>> extract a small image the crosses between the two doqqs, but I'm getting
>> a black line between them. When I serve them via mapserver, I'm not
>> getting this.
>> gdalbuildvrt -addalpha tmp-tc-13110.vrt m_4012408_sw_10_h_20160528.tif
>> m_4012416_nw_10_h_20160528.tif
>> gdal_translate -of GTiff -outsize 1360 1360 -projwin -124.083968798
>> 40.8779687978 -124.076031202 40.8700312022 -co TILED=YES -co
>> COMPRESS=JPEG -co JPEG_QUALITY=90 --config GDAL_TIFF_INTERNAL_MASK YES
>> tmp-tc-13110.vrt oaf2-tc.tif
>> I get the same result regardless of the -addalpha in the gdalbuildvrt
>> command.
>> What am I missing?
> If your tiles have colar (which I supposed since they have a mask),
> gdalbuildvrt (actually the VRT driver) doesn't take it into account as
> you might expect. It doesn't blend alpha/mask, but takes the alpha/mask
> value of the last source in the VRT that intersects the window of
> interest. You might have more success with
> gdalwarp in1.tif in2.tif out.tif -dstalpha -te xmin ymin xmax ymax
>> -Steve
>> $ gdalinfo m_4012408_sw_10_h_20160528.tif
>> Driver: GTiff/GeoTIFF
>> Files: m_4012408_sw_10_h_20160528.tif
>> Size is 11140, 10847
>> Coordinate System is:
>> GEOGCS["WGS 84",
>> DATUM["WGS_1984",
>> SPHEROID["WGS 84",6378137,298.257223563,
>> AUTHORITY["EPSG","7030"]],
>> AUTHORITY["EPSG","6326"]],
>> PRIMEM["Greenwich",0],
>> UNIT["degree",0.0174532925199433],
>> AUTHORITY["EPSG","4326"]]
>> Origin = (-124.127892543854088,40.939476459321497)
>> Pixel Size = (0.000006127013352,-0.000006127013352)
>> Metadata:
>> AREA_OR_POINT=Area
>> Image Structure Metadata:
>> COMPRESSION=YCbCr JPEG
>> INTERLEAVE=PIXEL
>> SOURCE_COLOR_SPACE=YCbCr
>> Corner Coordinates:
>> Upper Left (-124.1278925, 40.9394765) (124d 7'40.41"W, 40d56'22.12"N)
>> Lower Left (-124.1278925, 40.8730167) (124d 7'40.41"W, 40d52'22.86"N)
>> Upper Right (-124.0596376, 40.9394765) (124d 3'34.70"W, 40d56'22.12"N)
>> Lower Right (-124.0596376, 40.8730167) (124d 3'34.70"W, 40d52'22.86"N)
>> Center (-124.0937651, 40.9062466) (124d 5'37.55"W, 40d54'22.49"N)
>> Band 1 Block=256x256 Type=Byte, ColorInterp=Red
>> Overviews: 5570x5424, 2785x2712, 1393x1356, 697x678, 349x339,
>> 175x170, 88x85
>> Mask Flags: PER_DATASET
>> Overviews of mask band: 5570x5424, 2785x2712, 1393x1356, 697x678,
>> 349x339, 175x170, 88x85
>> Band 2 Block=256x256 Type=Byte, ColorInterp=Green
>> 175x170, 88x85
>> Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
>> 175x170, 88x85
>> $ gdalinfo m_4012416_nw_10_h_20160528.tif
>> Files: m_4012416_nw_10_h_20160528.tif
>> Size is 11145, 10851
>> GEOGCS["WGS 84",
>> DATUM["WGS_1984",
>> Origin = (-124.127899397118711,40.876995871942221)
>> Pixel Size = (0.000006124881549,-0.000006124881549)
>> Metadata:
>> AREA_OR_POINT=Area
>> INTERLEAVE=PIXEL
>> Corner Coordinates:
>> Upper Left (-124.1278994, 40.8769959) (124d 7'40.44"W, 40d52'37.19"N)
>> Lower Left (-124.1278994, 40.8105348) (124d 7'40.44"W, 40d48'37.93"N)
>> Upper Right (-124.0596376, 40.8769959) (124d 3'34.70"W, 40d52'37.19"N)
>> Lower Right (-124.0596376, 40.8105348) (124d 3'34.70"W, 40d48'37.93"N)
>> Center (-124.0937685, 40.8437653) (124d 5'37.57"W, 40d50'37.56"N)
>> Overviews: 5573x5426, 2787x2713, 1394x1357, 697x679, 349x340,
>> 175x170, 88x85
>> Overviews of mask band: 5573x5426, 2787x2713, 1394x1357, 697x679,
>> 349x340, 175x170, 88x85
>> 175x170, 88x85
>> 175x170, 88x85
>> This email has been checked for viruses by Avast antivirus software.
>> https://www.avast.com/antivirus
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Spatialys - Geospatial professional services
> http://www.spatialys.com
