[gdal-dev] Symlinks to VRTs
Even Rouault even.rouault at spatialys.com
Wed Mar 8 12:28:34 PST 2017
On mercredi 8 mars 2017 19:38:24 CET Luis Ressel wrote:
> Hello,
> VRTs can reference other files by relative paths. Upon reading such a
> VRT, GDAL will evaluate the relative path based on the directory where
> the VRT resides. Now, imagine the following situation:
> * There's a directory a/ containing several raster files and a VRT
>   referencing them.
> * There's a second directory b/ containing a symlink to the VRT in a/ .
> When I point GDAL at b/symlink.vrt, it will dereference the symlink
> before evaluating the relative paths inside the VRT (and thus search
> for the rasters in a/), whereas I would've expected GDAL to handle
> the symlink transparently and search for the rasters in b/ .
> Is this the intended behaviour?
Given that the existing behaviour is a reasonable one, I'd say yes. That's said your use can can
probably also makes sense.
> Unfortunately, I can't make much
> sense of the relevant code in gdal/frmts/vrt/vrtsources.cpp.
The relevant piece of code is in
https://github.com/OSGeo/gdal/blob/trunk/gdal/frmts/vrt/vrtdataset.cpp#L739
If you look a bit below in
https://github.com/OSGeo/gdal/blob/trunk/gdal/frmts/vrt/vrtdataset.cpp#L814
there's an open option ROOT_PATH that could be set to b/ to get the behaviour you wish.
Or you could add an open option, RESOLVE_SYMLINK=NO, to disable the stuff at
https://github.com/OSGeo/gdal/blob/trunk/gdal/frmts/vrt/vrtdataset.cpp#L745
Evn
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170308/1f391496/attachment.html>
