[gdal-dev] compiling gdal with esri file gdb
Robert Coup robert.coup at koordinates.com
Fri Mar 10 04:57:05 PST 2017
Hi Even,
On 9 March 2017 at 23:03, Even Rouault <even.rouault at spatialys.com> wrote:
> For those, at least on Linux, and which use GDAL compiled *without*
> --with-static-proj, you may get strange projection related failures at
> runtime. This is due to libFileGDBAPI.so embedding a copy of proj.4
> (without symbol hidding or renaming !!!), which conflicts with the proj.4
> that GDAL will load dlopen(). Typical error emitted is about "unknown
> ellipsoid".
I presume there's no workaround apart from --with-static-proj that doesn't
require ESRI to change their build process?
Cheers,
Rob :)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170310/fa69805e/attachment.html>
