[gdal-dev] compiling gdal with esri file gdb
Richard Greenwood richard.greenwood at gmail.com
Fri Mar 10 16:05:19 PST 2017
If any of you can share any pointers on how to even get it to compile I'd
appreciate it. I just need to access a esri file geodatabase that has
curves and see if I can get them into postgis. If I have to have a separate
build of gdal just for that I don't care. But I'm not too good with
compiling gdal with 3rd party libraries.
Thanks,
Rich
On Fri, Mar 10, 2017 at 10:16 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On vendredi 10 mars 2017 12:57:05 CET Robert Coup wrote:
> > Hi Even,
> > On 9 March 2017 at 23:03, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > > For those, at least on Linux, and which use GDAL compiled *without*
> > > --with-static-proj, you may get strange projection related failures at
> > > runtime. This is due to libFileGDBAPI.so embedding a copy of proj.4
> > > (without symbol hidding or renaming !!!), which conflicts with the
> proj.4
> > > that GDAL will load dlopen(). Typical error emitted is about "unknown
> > > ellipsoid".
> > I presume there's no workaround apart from --with-static-proj that
> doesn't
> > require ESRI to change their build process?
> Hi Rob,
> Yeah, I'm not even sure if --with-static-proj (which contrary to what its
> name my suggst will link against libproj.so if found) is completely safe,
> but it did work for me.
> Strangely, even without --with-static-proj, it worked for me at first, but
> then failed when I probably reordered paths in my LD_LIBRARY_PATH. But I'm
> not so surprised: clashing symbols issues tend to be not predictable.
> In fact, libFileGDBAPI.so doesn't seem to embed all public proj.4 symbols.
> The functions are missing. But 5 or 6 global array structures, like the
> list of datums (pj_datums) are exposed in the data read-only section. The
> issue is that pj_datums doesn't seem to have the same structure: 2 columns
> per record in the ESRI version whereas official proj.4 expects 4 columns
> $ objdump -T /home/even/FileGDB_API-64gcc51/lib/libFileGDBAPI.so | grep
> pj_
> 00000000010dc880 g DO .data.rel.ro 00000000000000b0 Base pj_datums
> 0000000001294080 g DO .data.rel.ro 0000000000000570 Base pj_projections
> 00000000010dbd20 g DO .data.rel.ro 0000000000000500 Base pj_pids
> 00000000010dc7a0 g DO .data.rel.ro 00000000000000e0 Base pj_primems
> 00000000010dc380 g DO .data.rel.ro 0000000000000420 Base pj_ellipses
> 00000000010dc220 g DO .data.rel.ro 0000000000000160 Base pj_linunits
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Richard W. Greenwood, PLS
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170310/41460ad0/attachment.html>
