[gdal-dev] compiling gdal with esri file gdb
Richard Greenwood richard.greenwood at gmail.com
Sat Mar 11 06:15:27 PST 2017
On Sat, Mar 11, 2017 at 1:34 AM, Damian Dixon <damian.dixon at gmail.com>
wrote:
> Have you tried OpenFileGDB? (you will need GDAL 2.2 or newer for curve
> geometries).
I would prefer OpenFileGDB but how do I enable it? configure --help says:
   --with-fgdb=ARG  Include ESRI File Geodatabase support (ARG=FGDP API
Path, yes or no)
so i tried
  --with-fgdb=yes
and got error:
  configure: error: FileGDBAPI not found
so I got the ESRI SDK and configured with
  --with-fgdb=/mnt/e/src/FileGDB_API-64/
but when I make I get many "undefined reference to FileGDBAPI..." errors.
Thanks,
Rich
> See: http://www.gdal.org/drv_openfilegdb.html
> We have switched to OpenFileGDB because ESRI don't have their library
> available on Windows built against VS2015. Which also means we did not
> bother with the ESRI libraries on Linux either.
> The other option is to use GDAL on Windows to convert the file. The way
> shared libraries work on Windows means that the proj4 issue you are seeing
> on Linux should not occur.
> I don't know where you would get a Windows build of GDAL with FileGDB
> enabled. Someone on the list probably does.
> On 11 March 2017 at 00:05, Richard Greenwood <richard.greenwood at gmail.com>
> wrote:
>> If any of you can share any pointers on how to even get it to compile I'd
>> appreciate it. I just need to access a esri file geodatabase that has
>> curves and see if I can get them into postgis. If I have to have a separate
>> build of gdal just for that I don't care. But I'm not too good with
>> compiling gdal with 3rd party libraries.
>> Thanks,
>> Rich
>> On Fri, Mar 10, 2017 at 10:16 AM, Even Rouault <
>> even.rouault at spatialys.com> wrote:
>>> On vendredi 10 mars 2017 12:57:05 CET Robert Coup wrote:
>>> > Hi Even,
>>> > On 9 March 2017 at 23:03, Even Rouault <even.rouault at spatialys.com>
>>> wrote:
>>> > > For those, at least on Linux, and which use GDAL compiled *without*
>>> > > --with-static-proj, you may get strange projection related failures
>>> at
>>> > > runtime. This is due to libFileGDBAPI.so embedding a copy of proj.4
>>> > > (without symbol hidding or renaming !!!), which conflicts with the
>>> proj.4
>>> > > that GDAL will load dlopen(). Typical error emitted is about "unknown
>>> > > ellipsoid".
>>> > I presume there's no workaround apart from --with-static-proj that
>>> doesn't
>>> > require ESRI to change their build process?
>>> Hi Rob,
>>> Yeah, I'm not even sure if --with-static-proj (which contrary to what
>>> its name my suggst will link against libproj.so if found) is completely
>>> safe, but it did work for me.
>>> Strangely, even without --with-static-proj, it worked for me at first,
>>> but then failed when I probably reordered paths in my LD_LIBRARY_PATH. But
>>> I'm not so surprised: clashing symbols issues tend to be not predictable.
>>> In fact, libFileGDBAPI.so doesn't seem to embed all public proj.4
>>> symbols. The functions are missing. But 5 or 6 global array structures,
>>> like the list of datums (pj_datums) are exposed in the data read-only
>>> section. The issue is that pj_datums doesn't seem to have the same
>>> structure: 2 columns per record in the ESRI version whereas official proj.4
>>> expects 4 columns
>>> $ objdump -T /home/even/FileGDB_API-64gcc51/lib/libFileGDBAPI.so | grep
>>> pj_
>>> 00000000010dc880 g DO .data.rel.ro 00000000000000b0 Base pj_datums
>>> 0000000001294080 g DO .data.rel.ro 0000000000000570 Base pj_projections
>>> 00000000010dbd20 g DO .data.rel.ro 0000000000000500 Base pj_pids
>>> 00000000010dc7a0 g DO .data.rel.ro 00000000000000e0 Base pj_primems
>>> 00000000010dc380 g DO .data.rel.ro 0000000000000420 Base pj_ellipses
>>> 00000000010dc220 g DO .data.rel.ro 0000000000000160 Base pj_linunits
>>> Even
>>> Spatialys - Geospatial professional services
>>> http://www.spatialys.com
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Richard W. Greenwood, PLS
>> www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170311/7c74f8ff/attachment-0001.html>
