[gdal-dev] compiling gdal with esri file gdb
Richard Greenwood richard.greenwood at gmail.com
Sat Mar 11 07:21:45 PST 2017
On Sat, Mar 11, 2017 at 7:20 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On samedi 11 mars 2017 07:15:27 CET Richard Greenwood wrote:
> > On Sat, Mar 11, 2017 at 1:34 AM, Damian Dixon <damian.dixon at gmail.com>
> > wrote:
> > > Have you tried OpenFileGDB? (you will need GDAL 2.2 or newer for curve
> > > geometries).
> > I would prefer OpenFileGDB but how do I enable it?
> It is a built-in driver. No option.
> --with-fgdb is when you want to enable the FileGDB driver that relies on
> the ESRI SDK
Thanks! When I did ./configure and saw "FGDB support: no"  I thought that I
had to set --with-fgdb.
Richard W. Greenwood, PLS
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170311/177fa1e0/attachment.html>
