[gdal-dev] GeoPackege, views and spatial index
Even Rouault even.rouault at spatialys.com
Thu Mar 16 16:38:01 PDT 2017
On jeudi 16 mars 2017 21:45:09 CET Rahkonen Jukka (MML) wrote:
> Hi,
> I can create a spatial view into GeoPackage database by following the
> document http://www.geopackage.org/modeling_guidelines.html and I can open
> such a view with QGIS. But have I understood right that there is no way in
> GeoPackage to link the R-Tree spatial index of the main table with the
> view? In Spatialite it is possible via the views_geometry_columns table but
> I can't find anything like that from the GeoPackage specification. I wonder
> if GDAL and QGIS could have support for same kind of linking metadata table
> than Spatialite.
I've just committed code to automatically figures out if a view refers to the FID and geom
column of a table that has a spatial index, and in that case to use it. This however requires
SQLite to be compiled with  -DSQLITE_ENABLE_COLUMN_METADATA. On Linux, GDAL
automatically detects if this is available. On Windows,
SQLITE_HAS_COLUMN_METADATA=yes must be manually defined in nmake.opt.
I see Tamas' build don't have SQLITE_HAS_COLUMN_METADATA=yes enabled, althoug the
sqlite3.dll has been compiled in that mode.
I've opened https://github.com/gisinternals/buildsystem/issues/106 on this.
@jef
Looking at OSGeo4W, the situation is a bit different since it seems that the sqlite3.dll is not
built with -DSQLITE_ENABLE_COLUMN_METADATA
I've created https://trac.osgeo.org/osgeo4w/ticket/524#ticket for that
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170317/898b613b/attachment.html>
