[gdal-dev] Help requested: Concurrent read of a GeoTiff
Grégory Bataille gregory.bataille at gmail.com
Tue Mar 21 01:38:45 PDT 2017
hum... debugging in the C layers, that'll be interesting...
Ok, I'll continue to dig in, thanks
Gregory Bataille
On Tue, Mar 21, 2017 at 8:44 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On mardi 21 mars 2017 05:51:18 CET Grégory Bataille wrote:
> > Hey Even,
> > reaching out again, because I just don't know...
> > so here is gdal2tiles_parallel strategy (as far as I understand it)
> > - in each process, open the input file, compute the autowarped vrt (in
> the
> > case of the dataset I use at least) loop over tiles to generate and work
> > only depending on the process number (so that this work is made in
> > parallel). We therefore end up with, in each process
> > - the input file opened as a dataset (but not touched after the
> > autowarped vrt is generated)
> > - a different autowarped vrt in memory (for each process) but pointing
> > to the same source (as far as I can see)
> > My strategy:
> > - open the input file.
> > - generate the autowarped vrt and save it to disk
> > - compute all the tile details and store them in a data structure.
> > Then in each process:
> I'm confused. You're talking about process, but is it a real operating
> system process or a thread ? I guess the later.
> > - take one tile detail
> > - open the vrt (same file for each process, pointing to the same source
> > TIFF)
> > - read the vrt and write the tile
> > And that's the read that is failing as mentioned in my first email.
> > I can't see much difference. To try and be complete, I tried to (or
> think I
> > tried to):
> > - open the input file in each process
> > - generate a different vrt file for each thread
> > I even copy/pasted the code that gdal2tiles_parallel uses in their
> > processes, but with no success, always the same error. The
> > VRT_SHARED_SOURCE option
> > does not seem to change anything (but looking at the wiki, it's not clear
> > whether it applies to autowarped vrt too)
> VRT_SHARED_SOURCE indeed only works for "regular" mosaicing VRTs. So not
> to warped VRT.
> Warped VRT opens the source dataset as a shared dataset in
> https://github.com/OSGeo/gdal/blob/trunk/gdal/alg/gdalwarper.cpp#L1675
> So you could have an issue if you open the VRT twice in the same thread,
> and then use each handle in a different thread, since both VRT handles
> would point to the same shared dataset. But it doesn't look that's what you
> are doing.
> As a workaround to investigate, you could try to remove the GDAL_OF_SHARED
> | flag in the line I mentionned and see if that makes a difference (but we
> could potentially - not sure - have issues at closing time since different
> call sites might make an assumption on the dataset being opened with shared
> semantics)
> What you could do too is run the script through your prefered debugger and
> set a breakpoint in GDALOpenEx and look at the calling sites. If you are
> using 2 threads, then if we want things to work correctly, GDALOpenEx()
> should be called twice on the TIFF dataset and return a different handle.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170321/442396b7/attachment.html>
