[gdal-dev] ogr2ogr GML GML_INVERT_AXIS_ORDER_IF_LAT_LONG not working
Norman Vine nhv at meganet.net
Wed Mar 22 01:02:41 PDT 2017
see
https://trac.osgeo.org/gdal/wiki/FAQVector#HowdoIflipcoordinateswhentheyarenotintheexpectedorder
> On Mar 22, 2017, at 2:41 AM, andye <awilliams at rapidmap.com.au> wrote:
> Folks related to a recent post about updating ogr2ogr. Seems there maybe
> something else afoot.
> I'm trying to export a GML3 file. I'm running into what appears to be a
> known issue with LAT\LONG being swapped based on the projection.
> The following creates a file which is formatted correctly except the desired
> output is LAT LONG. I get LONG LAT.
> Interestingly when I first tried this I have the -spat defined as LAT LONG
> and got no data. Once I changed it to LONG LAT the data was fine.
> I get identical result using QGIS to perform the same task with the same
> defined parameters.
> I also tried setting to NO to see if I was, in fact, swapping them but the
> result is the same no matter what.
> Taking the option out has no effect on the result.
> Am I mis-applying the creation option?
> ogr2ogr -f GML -spat 151.3085 -24.002934 151.394736 -23.963423 -clipsrc
> spat_extent -dsco FORMAT=GML3 -dsco GML3_LONGSRS=NO --config
> GML_INVERT_AXIS_ORDER_IF_LAT_LONG YES -dsco -dsco SPACE_INDENTATION=YES
> -dsco WRITE_FEATURE_BOUNDED_BY=NO -dsco XSISCHEMA=EXTERNAL -t_srs
> http://spatialreference.org/ref/epsg/4283/ "C:\export.gml" "C:\Import.tab"
> View this message in context: http://osgeo-org.1560.x6.nabble.com/ogr2ogr-GML-GML-INVERT-AXIS-ORDER-IF-LAT-LONG-not-working-tp5313555.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
