[gdal-dev] [GRASS-user] Slow import of GHSL
Markus Neteler neteler at osgeo.org
Fri Mar 24 06:09:00 PDT 2017
On Fri, Mar 24, 2017 at 10:25 AM, Nikos Alexandris
<nik at nikosalexandris.net> wrote:
> * Markus Metz <markus.metz.giswork at gmail.com> [2017-03-22 22:11:01 +0100]:
>> On Wed, Mar 22, 2017 at 9:52 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Markus N, I am interested: did you use the "memory" option?
I left r.in.gdal's default value.
> My understanding is that it would make a difference, for GRASS, if I
> would redo the GHSL layers with a row-shaped "block".  Makes sense?
Why spend time on redoing the GHSL layers? Do you have to import them
frequently?
markusN
