[gdal-dev] ogr2ogr GML GML_INVERT_AXIS_ORDER_IF_LAT_LONG not working
andye awilliams at rapidmap.com.au
Sun Mar 26 20:02:33 PDT 2017
Input.zip <http://osgeo-org.1560.x6.nabble.com/file/n5314350/Input.zip>
OutputOGR2OGR.GML
<http://osgeo-org.1560.x6.nabble.com/file/n5314350/OutputOGR2OGR.GML>
OutputQGIS.gml
<http://osgeo-org.1560.x6.nabble.com/file/n5314350/OutputQGIS.gml>
OutputMI.gml
<http://osgeo-org.1560.x6.nabble.com/file/n5314350/OutputMI.gml>
As suggested Jukka here is an example (in the zip file) of a Mapinfo TAB
file. the three GML files show an ogr2ogr conversion, QGIS conversion and
Mapinfo conversion to GML.
Here is the very simple command line I used to create the ogr2oge output.
ogr2ogr -f GML -t_srs "EPSG:4283" "C:\Output.GML" "C:\Input.TAB"
The issue as previously stated is the order of the latitude and longitude.
The Mapinfo(Universal translator built on FME) produces a LAT\LONG order by
default.
The ogr2 and QGIS both produce LONG\LAT.
Given the description on http://www.gdal.org/drv_gml.html
I added GML_INVERT_AXIS_ORDER_IF_LAT_LONG NO
ogr2ogr -f GML --config GML_INVERT_AXIS_ORDER_IF_LAT_LONG NO -t_srs
The result is unaltered.
I also tried adding GML_CONSIDER_EPSG_AS_URN YES
ogr2ogr -f GML --config GML_INVERT_AXIS_ORDER_IF_LAT_LONG NO --config
GML_CONSIDER_EPSG_AS_URN YES -t_srs "EPSG:4283" "C:\Output.GML"
"C:\Input.TAB"
No effect.
What am I missing?
View this message in context: http://osgeo-org.1560.x6.nabble.com/ogr2ogr-GML-GML-INVERT-AXIS-ORDER-IF-LAT-LONG-not-working-tp5313555p5314350.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
