[gdal-dev] Antwort: [Newsletter] Building GDAL on linux with minimal drivers
Niels.vonFestenberg-Packisch.ext at rohde-schwarz.com Niels.vonFestenberg-Packisch.ext at rohde-schwarz.com
Thu Mar 30 01:42:19 PDT 2017
Hi Gane,
it might be slightly heretic, but I succeeded in a similar task by using
GDAL version 1.11. In that version there seem to be much less
interdependencies between the dlls under Windows, and I guess it will be
the same under Unix.
I found out by starting the projects without any GDAL-dlls and then adding
them one by one until it worked (and I ended up with only two dlls). It's
a hack, but it worked for me.
Hope that helps.
Regards
Niels
Von:    Gane R <gane.prog at gmail.com>
An:     gdal-dev at lists.osgeo.org
Datum:  29.03.2017 11:17
Betreff:        [Newsletter] [gdal-dev] Building GDAL on linux with
minimal drivers
Gesendet von:   "gdal-dev" <gdal-dev-bounces at lists.osgeo.org>
Hi all,
I am looking for building gdal with minimal set of drivers like gdal with
geotiff, jpg, png and sqlite gpkg
so it should do basic warp geotiff and work with geopkg raster. I don't
need OGR part I need the core, alg and raster tif, gpkg, jpg and png alone
is enought.
the problem is I get a fat static lib. I want to reduce its size.
I tried to follow the post
https://trac.osgeo.org/gdal/wiki/BuildingOnUnixWithMinimizedDrivers It
seems it is old.
When I build i get error during building the apps like gdalinfo, gdalwarp
Any suggestions
my ogr/ogrsf_frmts/GNUmakefile  is
like
include ../../GDALmake.opt
SUBDIRS-yes    := \
    generic rec shape
SUBDIRS-$(HAVE_DODS)    += dods
SUBDIRS-$(HAVE_DWGDIRECT) += dxfdwg
SUBDIRS-$(HAVE_FME)    += fme
SUBDIRS-$(HAVE_GRASS)    += grass
SUBDIRS-$(HAVE_IDB)    += idb
I get the following error
/home/user/home/user/x64/gdal-2.1.0/.libs/libgdal.so: undefined reference
to `TABINDFile::~TABINDFile()'
to `TABINDFile::FindNext(int, unsigned char*)'
/home/user/x64/gdal-2.1.0/.libs/libgdal.so: undefined reference to
`gdal_json_object_object_add'
`TABINDFile::Open(char const, char const, int)'
`OGRMemLayer::CreateField(OGRFieldDefn*, int)'
`gdal_json_object_to_file'
`MITABSpatialRef2CoordSys(OGRSpatialReference*)'
`gdal_json_tokener_free'
`gdal_json_object_new_int64'
`gdal_json_object_get_string'
`OGRMemLayer::GetFeatureCount(int)'
`TABINDFile::BuildKey(int, int)'
`gdal_json_object_array_add'
`gdal_json_object_new_object'
`OGRXPlane_ExtendPosition(double, double, double, double, double*,
double*)'
`OGRMemLayer::SetNextByIndex(long long)'
`OGRMemLayer::CreateGeomField(OGRGeomFieldDefn*, int)'
`OGRMemLayer::ResetReading()'
`OGRMemLayer::ICreateFeature(OGRFeature*)'
`OGRXPlane_Distance(double, double, double, double)'
`TABINDFile::AddEntry(int, unsigned char*, int)'
`gdal_json_object_put'
`json_object_new_double_with_precision'
`OGRMemLayer::TestCapability(char const*)'
`OGRMemLayer::DeleteFeature(long long)'
`gdal_json_object_new_int'
`TABINDFile::Close()'
`gdal_json_object_get_type'
`OGRMemLayer::GetNextFeature()'
`OGRMemLayer::OGRMemLayer(char const, OGRSpatialReference,
OGRwkbGeometryType)'
`TABINDFile::BuildKey(int, char const*)'
`gdal_json_object_from_file'
Thanks
Gane_______________________________________________
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170330/97d20b9f/attachment.html>
