[gdal-dev] Issue building static only on OSX resolved in 2.2.0RC1
Roger Bivand Roger.Bivand at nhh.no
Thu May 4 01:25:36 PDT 2017
The R-core member working hard to keep up with OSX found issues building
GDAL static for the rgdal and sf R packages with GDAL 2.1.3 on El Capitan,
but reports success with GDAL 2.2.0RC1. I can't see the relevant line in
the NEWS file in 2.2.0RC1, so I'm posting this to keep his experiences on
the record - probably only a few downstream users need to build strictly
static.
Roger
The report:
"Two issues with --disable-shared --enable-static --with-pic that I
recall:
1) the default build fails due to an issue in the libtool linking
2) I got it to build by using --without-libtool
3) despite --disable-shared the result builds shared libgdal and links all
binaries against it (moreover the id path in the dylib is wrong)
so I don't have a fix, I have simply manually created libgdal.a, removed
.dylib so it won't be used and re-pointed the binaries into a versioned
path that is not used during linking phases. That'll all just a hack, it
doesn't "fix" it in the sources.
The details for 2.1.3:
if you want to raise this with GDAL -- the details:
## "regular" build
configure --with-pic --disable-shared --enable-static
--with-static-proj4=/usr/local/lib/libproj.a --with-liblzma
fails with
/Applications/Xcode.app/Contents/Developer/usr/bin/make libgdal.la
/bin/sh /Builds/unix/recipes/build/gdal-2.1.3-obj/libtool --mode=link
clang++    -L/usr/local/lib/libproj.a/lib -lproj  -lsqlite3 -lexpat
-L/usr/local/lib -lnetcdf -lhdf5_hl -lhdf5 -ldl -lm -lz -lcurl -lhdf5
-ljpeg
-lpng -llzma -lz -lpthread -ldl  -lpcre   -lcurl           -liconv  -lxml2
-lz -lpthread -licucore -lm    -o libgdal.la
/Builds/unix/recipes/build/gdal-2.1.3-obj/frmts/o/*.lo
/Builds/unix/recipes/build/gdal-2.1.3-obj/gcore/*.lo
/Builds/unix/recipes/build/gdal-2.1.3-obj/port/*.lo
/Builds/unix/recipes/build/gdal-2.1.3-obj/alg/*.lo
/Builds/unix/recipes/build/gdal-2.1.3-obj/apps/commonutils.lo
/Builds/unix/recipes/build/gdal-2.1.3-obj/apps/gdalinfo_lib.lo
/Builds/unix/recipes/build/gdal-2.1.3-obj/apps/gdal_translate_lib.lo
/Builds/unix/recipes/build/gdal-2.1.3-obj/apps/gdalwarp_lib.lo
/Builds/unix/recipes/build/gdal-2.1.3-obj/apps/ogr2ogr_lib.lo
/Builds/unix/recipes/build/gdal-2.1.3-obj/apps/gdaldem_lib.lo
/Builds/unix/recipes/build/gdal-2.1.3-obj/apps/nearblack_lib.lo
/Builds/unix/recipes/build/gdal-2.1.3-obj/apps/gdal_grid_lib.lo
/Builds/unix/recipes/build/gdal-2.1.3-obj/apps/gdal_rasterize_lib.lo
/Builds/unix/recipes/build/gdal-2.1.3-obj/apps/gdalbuildvrt_lib.lo
/Builds/unix/recipes/build/gdal-2.1.3-obj/ogr/ogrsf_frmts/o/*.lo
./ogr/ogrgeometryfactory.lo ./ogr/ogrpoint.lo ./ogr/ogrcurve.lo
./ogr/ogrlinestring.lo ./ogr/ogrlinearring.lo ./ogr/ogrpolygon.lo
./ogr/ogrutils.lo ./ogr/ogrgeometry.lo ./ogr/ogrgeometrycollection.lo
./ogr/ogrmultipolygon.lo ./ogr/ogrsurface.lo ./ogr/ogrmultipoint.lo
./ogr/ogrmultilinestring.lo ./ogr/ogrcircularstring.lo
./ogr/ogrcompoundcurve.lo ./ogr/ogrcurvepolygon.lo
./ogr/ogrcurvecollection.lo ./ogr/ogrmulticurve.lo
./ogr/ogrmultisurface.lo
./ogr/ogr_api.lo ./ogr/ogrfeature.lo ./ogr/ogrfeaturedefn.lo
./ogr/ogrfeaturequery.lo ./ogr/ogrfeaturestyle.lo ./ogr/ogrfielddefn.lo
./ogr/ogrspatialreference.lo ./ogr/ogr_srsnode.lo ./ogr/ogr_srs_proj4.lo
./ogr/ogr_fromepsg.lo ./ogr/ogrct.lo ./ogr/ogr_opt.lo
./ogr/ogr_srs_esri.lo
./ogr/ogr_srs_pci.lo ./ogr/ogr_srs_usgs.lo ./ogr/ogr_srs_dict.lo
./ogr/ogr_srs_panorama.lo ./ogr/ogr_srs_ozi.lo ./ogr/ogr_srs_erm.lo
./ogr/swq.lo ./ogr/swq_expr_node.lo ./ogr/swq_parser.lo
./ogr/swq_select.lo
./ogr/swq_op_registrar.lo ./ogr/swq_op_general.lo
./ogr/ogr_srs_validate.lo
./ogr/ogr_srs_xml.lo ./ogr/ograssemblepolygon.lo ./ogr/ogr2gmlgeometry.lo
./ogr/gml2ogrgeometry.lo ./ogr/ogr_expat.lo ./ogr/ogrpgeogeometry.lo
./ogr/ogrgeomediageometry.lo ./ogr/ogr_geocoding.lo ./ogr/osr_cs_wkt.lo
./ogr/osr_cs_wkt_parser.lo ./ogr/ogrgeomfielddefn.lo ./ogr/ograpispy.lo \
             -rpath /usr/local/lib \
             -no-undefined \
             -version-info 21:3:1
libtool: link:
`/Builds/unix/recipes/build/gdal-2.1.3-obj/frmts/o/BitMask.lo' is not a
valid libtool object
make[2]: *** [libgdal.la] Error 1
make[1]: *** [check-lib] Error 2
make: *** [gdal-2.1.3-dst] Error 2
$ file /Builds/unix/recipes/build/gdal-2.1.3-obj/frmts/o/BitMask.lo
/Builds/unix/recipes/build/gdal-2.1.3-obj/frmts/o/BitMask.lo: Mach-O
64-bit
object x86_64
--without-libtool
still creates a dylib and links all binaries against it:
clang++ -dynamiclib  ... -o
/Builds/unix/recipes/build/gdal-2.1.3-obj/libgdal.dylib
$ otool -L gdal-2.1.3-dst/usr/local/bin/gdal_grid
gdal-2.1.3-dst/usr/local/bin/gdal_grid:
(compatibility version 0.0.0, current version 0.0.0)
         /usr/lib/libsqlite3.dylib (compatibility version 9.0.0, current
version 216.4.0)
and anyway the ID is invalid (it's the build location, not the target)."
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
Editor-in-Chief of The R Journal, https://journal.r-project.org/index.html
http://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
