[gdal-dev] GDAL 2.1.3 with ECW support compile fails
Even Rouault even.rouault at spatialys.com
Thu May 4 06:21:47 PDT 2017
Liam,
> > …\gdal-2.1.3\frmts\ecw\ecwdataset.cpp(68): error C2440: 'initializing':
> > cannot convert from 'NCS::CString' to 'char *'
--> this line shouldn't be compiled when building against SDK >= 5.0. Check in
your nmake settings that -DECWSDK_VERSION=53 is defined
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170504/ff677d9e/attachment.html>
