[gdal-dev] Automating code style enforcement ?
Even Rouault even.rouault at spatialys.com
Thu May 4 13:49:40 PDT 2017
I've observed Kurt's continued efforts, over several months if not years, to set a consistant
style to the code base and this is a much appreciated initiative. Now, as this touches the
whole code base, I think this should be formalized, probably under the form of a RFC, so that
this is shared among all developers. Currently as there's no automation, basically every
committer will probably unconsciously "break" files that have been already reformatted,
which is a waste of time that could be avoided (and on a minor note we could save extra
reformatting commits that are noise in the history, and extra bits to parse for the human
preparing a changelog)
I've seen in other projects, like QGIS, a script (in QGIS, they rely on astyle ultimately. not
saying we should necessary use astyle) that takes care of reformatting automatically the files
to be committed given the rules. That way the effort is spread on all contributors (and it is
not a big deal to run this script). We could also have in Travis-CI a check so that pull requests
are verified to respect the style (currently, we have already a very adhoc scripts/
detect_tabulations.sh to check that no tabulation characters are used)
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170504/69a49ce1/attachment.html>
