[gdal-dev] WMTS "No zoom level found"
Hugues François hugues.francois at irstea.fr
Fri May 5 09:18:54 PDT 2017
Thanks for your quick reply. No, I did'nt try this simple command.
Here is the output (I removed some of them, keeping just the one I want to use but the whole output is attached to the message)
Regards,
Hug
gdalinfo "WMTS:http://wxs.ign.fr/{KEY}/geoportail/wmts?SERVICE=WMTS&REQUEST=GetCapabilities"Driver: WMTS/OGC Web Mab Tile ServiceFiles: none associatedSize is 512, 512Coordinate System is `'Origin = (0.000000000000000,0.000000000000000)Pixel Size = (1.000000000000000,1.000000000000000)Subdatasets:  SUBDATASET_89_NAME=WMTS:http://wxs.ign.fr/{KEY}/geoportail/wmts?SERVICE=WMTS&REQUEST=GetCapabilities,layer=GEOGRAPHICALGRIDSYST                  SUBDATASET_89_DESC=Layer PYRAMIDE SCANEXPRESS STANDARDCorner Coordinates:Upper Left  (   0.0000000,   0.0000000)Lower Left  (       0.000,     512.000)Upper Right (     512.000,       0.000)Lower Right (     512.000,     512.000)Center      (     256.000,     256.000)
----- Mail d'origine -----
De: Even Rouault <even.rouault at spatialys.com>
À: gdal-dev at lists.osgeo.org
Cc: hugfr <hugues.francois at irstea.fr>
Envoyé: Fri, 05 May 2017 17:19:27 +0200 (CEST)
Objet: Re: [gdal-dev] WMTS "No zoom level found"
p, li { white-space: pre-wrap; }
On vendredi 5 mai 2017 08:09:30 CEST hugfr wrote:> Hello,>> I try to create an xml file suitable for gdal wmts but I got this error "no> zoom level found" (when I try a gdalinfo) and I don't understand where does> the problem come from. I found this post about zoom level management :> http://osgeo-org.1560.x6.nabble.com/WMTS-Need-TileLevel-option-Servers-respo> nding-with-bad-capabilities-td5298089.html>> I tried the xml with gdalinfo and it runs perfectly. I compared with mine> and I didn't noticed major differences. I also took a comparative look at> servers capabilities which seems similars. The main difference lays in the> TileMatrix content.>> Here is "mine":> <TileMatrixSetLimits>> <TileMatrixLimits>> <TileMatrix>10</TileMatrix>> <MinTileRow>340</MinTileRow>> <MaxTileRow>400</MaxTileRow>> <MinTileCol>493</MinTileCol>> <MaxTileCol>546</MaxTileCol>> </TileMatrixLimits> Did you just trygdalinfo "WMTS:http://wxs.ign.fr/{KEY}/geoportail/wmts?SERVICE=WMTS&REQUEST=GetCapabilities" If it does not, then attaching the response to this GetCapabilities requestmight help investigating the issue. Even --Spatialys - Geospatial professional serviceshttp://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170505/136e21cf/attachment-0001.html>
