[gdal-dev] Binary of the latest released GDAL for travis?
Johan Van de Wauw johan.vandewauw at gmail.com
Mon May 8 04:40:21 PDT 2017
Ari,
I had similar problems. The problem is that an old version of gdal is
installed by travis by default (!)
adding
before-install:
- sudo apt-get remove -y libgdal1
fixed this for me on trusty (and on precise, but you will still not
get the latest version).
Kind Regards,
Johan
On Tue, Apr 11, 2017 at 12:48 PM, Ari Jolma <ari.jolma at gmail.com> wrote:
> 11.04.2017, 13:28, Bas Couwenberg kirjoitti:
>> On 2017-04-11 12:22, Ari Jolma wrote:
>>> 11.04.2017, 13:05, Angelos Tzotsos kirjoitti:
>>>> Hi Ari,
>>>> sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
>>>> sudo apt-get update
>>>> sudo apt-get install libgdal-dev
>>>> This should do it.
>>> No. I tried that before (found it in my .travis.yml file...) and it
>>> pulls in older version 1.10.0.
>> You can install the 2.1.3 version explicitly with:
>>  sudo apt-get install libgdal-dev=2.1.3+dfsg-1~xenial2
> It seems it did not even try this. Probably because it is precise?
>> But this will fail when the version is updated in the PPA.
>> Is the travis environment using Ubuntu xenial, and not an older LTS like
>> trusty or precise? It's probably trusty since that ships with GDAL 1.10.1.
> It is precise. Trusty build environment is in beta.
>> For those older LTS releases the UbuntuGIS packages haven't been updated
>> yet. Depending on manpower and motivation we may be able to updated the
>> trusty packages in the near future.
> It would save a lot of build time at least for me.
> The reason for me is that many of my project use the GDAL Perl bindings and
> for the tests I pull in the latest from CPAN, which is based on the latest
> released GDAL.
>> Ideally the travis environment is upgraded to xenial for which the best
>> support is available and the default packages in Ubuntu itself are much more
>> current.
> ok
> Thanks,
> Ari
>> Kind Regards,
>> Bas
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
