[gdal-dev] Convert false-color single band tiff to png
Paul Meems bontepaarden at gmail.com
Tue May 9 05:56:29 PDT 2017
Thanks Even,
I did look at the -scale switch but probably not correct.
This is working:
Regards,
Paul
2017-05-09 14:28 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> On mardi 9 mai 2017 14:25:58 CEST Paul Meems wrote:
> > I'm having trouble converting a false-color single band tiff to png.
> > Most of my tiff-files I can convert using GdalDem and a color table, this
> > works great.
> > But some tiff-files are pre-processed and I need to convert them as is.
> > This is the tiff:
> > [image: Inline afbeelding 1]
> > I tried with gdal_translate:
> > But then I get a mostly white png. I also tried several other options.
> > The range of the tiff-file is from 1842 - 2636.
> > Does this mean I'm bound to use a color table file and use GdalDem or is
> > another solution possible?
> Look at the -scale switch of gdal_translate
> > The tiff-files are send to my from an outside source I have no control
> > about them.
> > I need the png-files because I'm showing the files in OpenLayers.
> > How can I do the conversion properly?
> > Thanks,
> > Paul Meems
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170509/f4d35ba5/attachment.html>
