[gdal-dev] Building GDAL on linux with minimal drivers
Gane R gane.prog at gmail.com
Wed May 10 05:46:51 PDT 2017
I got it working, I saw the post Handling pdfium build / integration and
fixed it.
On Wed, Mar 29, 2017 at 2:47 PM, Gane R <gane.prog at gmail.com> wrote:
> Hi all,
> I am looking for building gdal with minimal set of drivers like gdal with
> geotiff, jpg, png and sqlite gpkg
> so it should do basic warp geotiff and work with geopkg raster. I don't
> need OGR part I need the core, alg and raster tif, gpkg, jpg and png alone
> is enought.
> the problem is I get a fat static lib. I want to reduce its size.
> I tried to follow the post https://trac.osgeo.org/gdal/wiki/
> BuildingOnUnixWithMinimizedDrivers It seems it is old.
> When I build i get error during building the apps like gdalinfo, gdalwarp
> Any suggestions
> my ogr/ogrsf_frmts/GNUmakefile  is
> like
> include ../../GDALmake.opt
> SUBDIRS-yes    := \
>     generic rec shape
> SUBDIRS-$(HAVE_DODS)    += dods
> SUBDIRS-$(HAVE_DWGDIRECT) += dxfdwg
> SUBDIRS-$(HAVE_FME)    += fme
> SUBDIRS-$(HAVE_GRASS)    += grass
> SUBDIRS-$(HAVE_IDB)    += idb
> I get the following error
> /home/user/home/user/x64/gdal-2.1.0/.libs/libgdal.so: undefined reference
> to `TABINDFile::~TABINDFile()'
> to `TABINDFile::FindNext(int, unsigned char*)'
> /home/user/x64/gdal-2.1.0/.libs/libgdal.so: undefined reference to
> `gdal_json_object_object_add'
> `TABINDFile::Open(char const, char const, int)'
> `OGRMemLayer::CreateField(OGRFieldDefn*, int)'
> `gdal_json_object_to_file'
> `MITABSpatialRef2CoordSys(OGRSpatialReference*)'
> `gdal_json_tokener_free'
> `gdal_json_object_new_int64'
> `gdal_json_object_get_string'
> `OGRMemLayer::GetFeatureCount(int)'
> `TABINDFile::BuildKey(int, int)'
> `gdal_json_object_array_add'
> `gdal_json_object_new_object'
> `OGRXPlane_ExtendPosition(double, double, double, double, double*,
> double*)'
> `OGRMemLayer::SetNextByIndex(long long)'
> `OGRMemLayer::CreateGeomField(OGRGeomFieldDefn*, int)'
> `OGRMemLayer::ResetReading()'
> `OGRMemLayer::ICreateFeature(OGRFeature*)'
> `OGRXPlane_Distance(double, double, double, double)'
> `TABINDFile::AddEntry(int, unsigned char*, int)'
> `gdal_json_object_put'
> `json_object_new_double_with_precision'
> `OGRMemLayer::TestCapability(char const*)'
> `OGRMemLayer::DeleteFeature(long long)'
> `gdal_json_object_new_int'
> `TABINDFile::Close()'
> `gdal_json_object_get_type'
> `OGRMemLayer::GetNextFeature()'
> `OGRMemLayer::OGRMemLayer(char const, OGRSpatialReference,
> OGRwkbGeometryType)'
> `TABINDFile::BuildKey(int, char const*)'
> `gdal_json_object_from_file'
> Thanks
> Gane
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170510/7cb40b91/attachment-0001.html>
