[gdal-dev] Build PDFium with GDAL
Gane R gane.prog at gmail.com
Wed May 10 05:48:19 PDT 2017
I got it working, I saw the post Handling pdfium build / integration and
fixed it.
On Tue, May 9, 2017 at 6:31 PM, Gane R <gane.prog at gmail.com> wrote:
> Hi all,
> I am trying to build GDAL with PDFium
> I saw the link
> https://github.com/rouault/pdfium/tree/build
> I tried to use the linux script and the pdfium static lib to build. *pdfium
> build succeed.*
> I have few Questions:
> Q1: I see some 3rdpary dependency for PDFium, I don't see those LICENSES
> included, does overall including the 3rparty dependency, PDFium library
> comes to point like similar to MIT license ?.
> Q2. Can we do a cross compile with for PDFium, or any one tried.
> Q3. Has any one got an error like this (error message follows in next few
> lines) ? or I have gone wrong in build steps.
> I started to build GDAL gdal-2.2.0 with pdfium
> ./configure --with-pdfium=/home/pdfium/install
> libtool: link: g++ .libs/gdalinfo_bin.o -o .libs/gdalinfo
> /home/works/gdal_fresh/gdal-2.2.0/.libs/libgdal.so -L/home/pdfium/install
> -L/home/pdfium/install/lib/pdfium -lpdfium -lfpdfapi -lfpdftext
> -lformfiller -lpdfwindow -lfxedit -lfpdfdoc -lfxcodec -lfx_libopenjpeg
> -lfx_lcms2 -lfx_libjpeg -lfx_zlib -lfdrm -lfxge -lfreetype -lfx_agg -lfxcrt
> -lbigint -lz -lpthread -lrt -ldl
> /usr/bin/ld: .libs/gdalinfo: hidden symbol `_ZN13CFDF_Document12CreateNewDocEv'
> in /home/pdfium/install/lib/pdfium/libfpdfapi.a(fpdf_parser_fdf.o) is
> referenced by DSO
> /usr/bin/ld: final link failed: Bad value
> collect2: error: ld returned 1 exit status
> GNUmakefile:82: recipe for target 'gdalinfo' failed
> make[1]: *** [gdalinfo] Error 1
> make[1]: Leaving directory '/home/works/gdal_fresh/gdal-2.2.0/apps'
> GNUmakefile:93: recipe for target 'apps-target' failed
> make: *** [apps-target] Error 2
> Thanks
> Gane R
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170510/5fdf4301/attachment.html>
